Geico266
I hate flying with oil temps that don't hit 210F at least once a flight. This is impossible to do with a Lycoming in the winter unless you block off the oil cooler. Well, that is all well and good it you fly local, but I can go from the frozen NE tundra to temperate AZ in 5 hours. An inflight adjustable oil cooler is very handy. I've installed Van's inflight adjustable oil cooler shutter doors on a couple of 0-360's with great success, but they are for rectangular openings. Temps in the winter can be maintained quite nicely to 200F, this keeps moisture build up to a minimum in winter. Less water, less corrosion.
Anyone do this on a -10 with an IO-540? I know a guy in Tea, SD did one, but I don't have a picture of it. Anyone make one and can share a pic?
Any ideas?
As always thnaks in advance for any help / advice.
Any ideas?
