humptybump
My iGate has been running for almost two years now. Other than a tiny bit of electricity, there are no re-occurring cost and a tiny bit of attention once in a while. My iGate fills a substantial void along the eastern seaboard - it's on track for transferring 18,000 messages to the Internet this month!
While its not a critical component of my RV-8 flying, I like having it on board and my family likes being able to see where my plane is. I also like "checking up" on friends who fly more than me ... vicarious aviation. Parents with kids who are new drivers - or will be soon - might want to consider adding trackers to their cars too![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'd like to help others who are willing to stand up an iGate. You need an amateur radio license, but thats not a difficut written test to pass and the same licence covers your tracker. If you check you local area and find there is no iGate in your area then you are a good candidate. If there is no iGate at your airport and the FBO has WiFi, then you are a good candidate (although you may need to check airport rules about the antenna). Alternately, you can set one up at home.
Here is the real world cost of equipment:
The installation of the antenna is just a matter of finding a location for the antenna and running the feed line coax from the antenna to wherever the computer and radio will be. There's not much I can do here unless you are within RV distance.
Before I forget - you will need access to an internet connection too. I use low power laptops which can support WiFi or wired network. This provides a few more options for locating the iGate.
What's not included here is the cost of "elevation". If you are trying to cover a large area with your iGate, you need you antenna to be able to have a better "view" of the area. If your area is relatively flat, then you don't need much elevation but if you are in a low spot, getting some elevation will help but also cost. The simplest option is to mount the external antenna at the peak of a roof - either on top of the peak or close to the peak on the end of a building. You can see my installation is on the end of my hangar sticking above the peak. The ultimate solution is a tower but that is costly and also will increase the length of the coax feed line which in turn dictates using higher quality / higher cost material.
Tracking down the parts is pretty easy too. I'm happy to share my sources (but everything I bought came from Amazon, eBay, and my local HW store so it's mostly a personal choice)
For most, the challenge is getting the computer software installed, configured, connected to the radio, and all tuned up. Here is where I hope to help.
I'm happy to setup, configure and tune up the computer and radio and help train you with operating your iGate.
I realize this is not for everyone. But, if you are game, so am I. Even if this only nets a couple new iGates, if it fills in some voids across the country or across the globe, it will be a fun project.
- a 2-meter receiver (eBay has several hand held HAM radios for $50-75)
- a permanent antenna (a new copper j-pole is about $45)
- antenna feed cable (50ft of coax with connectors is about $25)
- a computer with a sound card / mic input (an OLPC XO is about $50-$75 on eBay, a Raspberry PI setup can be put together for about the same)
- an audio cable and probably a data cable or two (likely less than $10)
- misc mounting hardware will be another $10-$20
