I had quite the problem diagnosing a faulty "B" ignition on my RV-12 on first engine run. Swapped modules, checked wiring, pulled off glare shied & checked switch(es), etc. Finally found problem where the "kill" wire is grounded with a clamp holding many other items near the ignition modules. Learned from an expert that a clamp is no way to ground a shielded (co-ax) cable. In my case, the clamp had squeezed the shielding so hard that it grounded against the central conductor of its own cable, rendering that ignition inoperative.
The right way to do it (which we did and solved the problem) is to clip and twist the shielding separately, attach a lug, and ground properly to a screw.
Save yourself this immense nuisance. The only "field" wiring on the ignition for the RV-12 builder is to attach 2 white wires to existing plugs. These are the "kill" wires for each module, "A" & "B". Take the time to route and ground these wires properly, or you, too, may end up with a $28K engine that runs like **** from the get-go.
