Ignition Wiring Harness 46-12
McSteff
Member
46-12 Step 2: Insert the WH-152 Ignition A Wire into the "unused socket" of conenctor A1
Problem: Looking at my Rotax engine, all 6 sockets of A1, A2, B1 and B2 are used. No unused ones to insert the ignition wire harness
Solution? No idea.....
Any builders out there that faced the same issue?
Good progress
You must have been working like a Trojan if you're up to 46-12 already. What would that be .... 4-5 months since first rivet ??
