While tie-wrapping the firewall-forward wiring I put some tension on the 2-pin molex for the ignition harness (two thick white wires) and one wire popped right out! The molex pin stayed in the connector so I used a small piece of hose as a pin remover to push in the molex pin's locking clip and the pin came right out. I noted that the crimp was not fully completed on this pin so I stripped a bit more wire and re-crimped it as I didn't have a replacement pin that size.
All is now nice and tight but you should all do some careful pulling on the various connectors before you tie-wrap to make sure you have good crimps. Stein does great work and this is the FIRST little flaw I've found so far.
The tie-wrapping is now complete and they guys are painting the cowlings. Soon...
-Neil
-Neil
