I have a new Lycoming IO-390 and I am exchanging the right magneto with a Lightspeed Plasma III. The Lightspeed manual recommends using the top side of the cylinders for the Plasma plugs and the bottom side for the Slick magneto. The right mag. fires up the bottom plugs on the right side and the top plugs on the left side as is. I doubt ,but will verify that the magneto will have issue with firing the bottom plugs but my leads are too short if I move from the top location to the bottom.
My Plasma leads are also to short to reach to the bottom position on the left side also. If the right mag. can indeed fire the bottom plugs can I exchange the two left leads with some of the correct length from the left mag. I removed?
Any help on this topic would greatly be appreciated as always.
Thanks Ron
Thanks Ron
