ccsmith51
I have the all-weather harness (3/4" nuts on the plugs) on my O-360. On a couple of plugs the shield has pulled away from the nut, exposing the rubber insulation of the ignition wire.
I am concerned that eventually the wire might chaff through and arc. I have thought about shoving some RTV around the wire to support it, but that seams too hokey...
Is there a way to remove the red rubber end that goes into the plug, shorten the wire, then reassemble so that the shield is once again down inside the nut?
