I am looking for a gps that is reasonable in price and has easy to use features that will drive an autopilot. The Ifly seems to fit the bill. does anyone have experience with these and how do you like it? Also I have installed a Westech CHT four positon unit and read where the cold junction is set to 75 degrees. The cold junction in installed in the engine compartment and I am sure varies greatly as to ambient temperature. The problem is if the temperature is 100 degrees the instrument has an error of -25 degrees. If the temperature is 50 degrees the error is +25 degrees. Does anyone have experience with these units and is there an installation trick that eliminates or lessens this error? If not I intend to get rid of it for one that is accurate without this problem. I have noticed on cool days that the cht runs at 425 to 450 on climb out which is not good. However I don't believe it is accurate. The number 2 and 4 cylinders are the hotest ones which doesn't make sense to me so this could be part of it since the cold junction is in the oil cooler side of the engine compartment. Anyone with actual experience would be helpful, Thanks.
