... and put the mag leads to the bottom cylinders and EI to the top cylinders
This is contrary to what some vendors recommend.
Jeff Rose (ElectroAir) recommended EI on bottom plugs where you are more likely to have oil and the hotter spark would burn through it better than the mag.
I have found this to absolutely true.
James
Which one should I get? I have an 0-320-E3D 160hp.
Thx.
Hugh.
I have never installed a mag (although used plenty. Does a Mag have just a ground wire running out of it once its installed connected to the ignition switch? Is it as simple as that or is there more complicated wiring involved?
I want to understand what I should expect in terms of installation effort. I realize timing etc. is something I will need some help with from my A&P (I did not build the plane myself).
Any info would be appreciated.
Thx.
Hugh.
That, plus four wires running to the spark plugs...
Yes, it is that simple. It is automatically grounded to the engine; self contained; and the P-Lead runs to a switch which, when closed, simply grounds it out to prevent it from firing.
I won't say dummy proof, because they are always making better dummies...
You should not rely on any automatic grounding at the magneto - this is a major safety issue.
Use the dedicated ground screw for a direct ground at each magneto...
This previous thread shows a picture of the ground location... it's not very obvious, being just a threaded hole....
http://www.vansairforce.com/community/showthread.php?t=25318&highlight=slick
My bad - I've never actually installed one myself.
Ok, half wrong. If you bolt it on correctly INCLUDING THE GROUNDING SCREW it is "automatically grounded..."
... your statement sort of implies that their is a grounding connection from the magneto to the engine (as you bolt it on)....
The grounding screw should be connected to the shield of the P-lead, and then the magneto switch connects (shorts) the shield to the core of the P-lead to make it "safe" - that is magneto OFF.
No grounding strap or connection is made from the magneto to the engine.
I rate it as being only 1/4 correct....![]()
So, if the above is correct then my ORIGINAL description was also correct - just missing the detail that the P-Lead shield is attached to the Magneto ground screw. That would leave my original description 100% correct, just incomplete...
