R
Rutus
My ICOM A200 has, so far, been reliable and easy to use. But last week the tower at Tacoma Narrows told me that I was garbled, weak, and had lots of static in transmissions when approaching the airport traffic area. Ground communications on 121.8 were loud and clear.
Prior to this, I had a couple flights where I picked up some odd interference on Tacoma's tower frequency, 118.5. One time, it sounded like someone had a stuck mike switch, because the frequency was full of engine-noise like sound. On a couple other occasions, on the same frequency, it sounded like some kind of marker beacon or the like spilling over onto the tower frequency.
Yesterday, I flew to eastern Washington and got radio checks at different airports on various frequencies. Everyone seemed to hear me loud and clear, and Seattle center and Seattle approach both thought I sounded fine.
Reception on all frequencies has always been great, and continues to be good even on Tacoma's tower frequency.
I am using 45 degree bent whip antenna mounted under the fuselage just to right of center. Previously, Tacoma tower has always heard me loud and clear, and as noted above, reception has always been excellent. Antenna connections, etc. were all checked 25 hrs ago at annual and were fine.
I use a Lightspeed 20XL headset, and when I transmit the sidetone sounds pretty normal in the earphones.
From all this, my amateur thinking is:
Antenna and cable are probably OK, given excellent reception and good radio checks on other frequencies;
Headset mike must be OK if the sidetone comes through normally;
ICOM maybe has something going belly up on the Tacoma tower frequency (I"ve heard of radios having problems on just one or two frequencies, and working fine on others).
I have another pair of Lightspeeds that I will use just to rule out mike problems, but in the meantime, does anyone have any ideas/suggestions for how to track this down? I thought it best to do some thinking, and get some feedback, before tearing into everything . . . TIA![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
