I'm having a bit of trouble with my A 210. The squelch opens all the time unless I have it set to the highest value or turn my GRT EFIS displays OFF. MY 430W mounted just above it works fine using the same antenna/coax .
The panel is just built and still on the bench.
I have tried to re-seat the molex connector/pins and removed all of the pins from the radio for swap, serial, audio panel etc. Right now I have only power, ground, speaker and antenna connected.
At this point I think it is the radio, if it was noise from the EFIS's I would expect the 430 to have the same issue. Also the radio seems to receive fine.
Software is vs. 1:43
Any comments or suggestions?
Thanks, Tim
Thanks, Tim
