Hi
The 10 isn't finished yet, but I need some measurements to do the hangar.
The hangar door isn't going to be more than 12.5', so there will be two extra set of door's so the wing's can get out of the weather as well.
I need the following measures to make everything fit nicely.
With the plane on a level surface:
What's the distance from the pitot tube to the ground?
What's the distance from the Flap hinges to the ground?
Thanks in advance
Palle Olesen
Thanks in advance
Palle Olesen
