I need a ring gear for an IO360M1B
No Spruce. I found that out on the field at Osh. SkyGeek has them. Duh, I did a search for the part number provided by Lycoming 72566.
Do you need the 149 tooth version with the small diameter pulley? If so I've got one. I needed the 149T large pulley for the LSE ignition; mine is from O-320-D3G and shows the same p/n
ring gear
I have several that are new I can sell for 65.00 each plus freight. Freight normally runs arounf 10-12 to a residence.
Jesse Robinson
970-209-0183
I got the new gear from SkyGeek. They actually drop shipped from Atlanta and I got it overnight.
I read the history and also found the Lycoming service instruction (circa 1965). This was about the easiest thing I have ever done.
Throw flywheel in the freezer overnight.
pre-heat oven to 500 degrees.
Bake the ring gear for 60 minutes.
Dropped right on.
In fifteen minutes, it was ambient temp and ready to bolt on.
Thanks VAF.
