N546RV
Semi-obligatory self-reflective intro: Is it just me, or do these moments always seem to come at the same sort of time? You're out in the shop, you get in a good groove, you're all pleased with your productivity...you might even, at some point, think to yourself, "I'd better be careful, or I'll get carried away and make a mistake..."
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Anyway, last night I match-drilled all the left elevator parts, and tonight I set about deburring and dimpling everything. I hit up all the usual stuff: spar, ribs, counterweight skin, etc. That list included my new best friend, E-606PP, on which I proceeded to intrepidly dimple both flanges.
That done, I was about ready to call it a night and head, inside, but I decided to read ahead in the instructions a bit. Well, what do you know...just a couple lines down it specifically addresses E-606PP, along the lines of "Machine countersink the top flange and dimple the bottom flange."
Internal head voice: "Countersink? Just the top? But why...ohhhhhh...the hinge for the trim tab goes there, and needs a flush surface to rest on."
*sigh*
I started to bust out the rivet gun, flush set, and back rivet plate to flatten out all those nice dimples I'd just made, but then realize I was getting right back into the mindset that caused the screw-up in the first place...too much working, not enough thinking.
Then I had another thought: Maybe I could just countersink the hinge piece itself and not have to go flatten all those dimples. Might make drilling the hinge in place a little more challenging, but at least I wouldn't risk messing up a bunch of previously good holes and having to reorder a part.
So, I submit the question to the peanut gallery: Which should I do? Flatten the dimples, countersink E-606PP, hope the holes don't get buggered? Or leave the dimples there and plan on countersinking the hinge?
I'm leaning towards countersinking the hinge, but I want to make sure I'm not overlooking some kind of problem that might result.
Thanks!
*sigh*
Thanks!
