b17fe said:(The fuse kit doesn't supply the center section.)
Steve-81604
AX-O said:It does nowThis is the what is says on the 4th issue 2006 RVator.
"Fuselage center sections bulkheads (F804) will now ship with the fuselage kit instead of the wing kit. Builders who already have an RV8/8A wing kit will have a center section fuselage bulkhead. When they receive the new matched-hole fuselage kit, they will get another one. The one in the fuselage kit should be used, and the unit provided in the wing kit discarded or returned to Van's. There's no credit for them, But it seem a shame to just toss out beautifully anodized components."
So I am turning the old bulkheads into a table.
mlwynn said:Last July, I had grandiose delusions that I would be done with the wing by now.....
Michael Wynn
RV 8 Wings (flaps)
gpiney said:I could not seem to get an acceptable answer from Vans. I am planning on building the Fuse BEFORE the Wings. I understand that with the new fuse kit, all parts necessary to build the fuse are included in the kit. However, I do not think this includes the wing spar center section. My question is whether the new fuse can be built without the spar center section available to the builder. Would whoever has the new instructions please check and see if the bulk of the fuse can be built without the spar center section.
Thanks in advance
Guy Prevost said:When I talked to them they indicated that the spar center section is included in the new kits. I'll have mine in 2 weeks or so. If you haven't heard from someone else by then, I'll let you know. I believe that I will also have and extra spar center section since one came with my wings. If that winds up being the case, I would be willing to give it to you.
Guy
