A HydroPneumatic Rivet Squeezer which can accept standard C-yokes is now available (albeit in still limited quantities for now). I am continuing to ramp up production. Below is where they are sold:
http://www.cleavelandtoolstore.com/products.asp?dept=117
The compact version of the squeezer was demonstrated at Oshkosh 2010, and many asked for this standard version, so here it is. Model 3060-1. Also available is a powered head for the DRDT-2 unit. Model 3400-1.
The below link shows a size comparison with a traditional squeezer:
http://www.cleavelandtoolstore.com/images/SHPS3060-alt2.jpg
The units are precision designed in Unigraphics NX4, as shown in this link:
http://www.cleavelandtoolstore.com/images/SHPS3060-alt.jpg
The MDS squeezer is obviously smaller (and thus lighter) than a traditional pneumatic squeezer. But less obvious is the fact that the unit produces constant force, as compared to the traditional pneumatic only squeezer which has a peak force range of about .030". This means less fiddling with the compression pin or squeezing the rivet twice to set the final height. The new squeezer is almost 3 lb lighter than the WWII style squeezer shown. A QD (quick disconnect) makes it a snap to plug in different heads. The QD also provides another degree of freedom, in rotation. Couple this with the lighter weight means less wrist fatigue, due to a significantly lower moment of inertia.
These are the heads currently available to be powered by the MDS intensifier, but rest assured there will be more heads available. So, if you invest in the HPRS it wont just gather dust (until the project is competed, then either start a new project, or sell the unit on ebay). A pop riveter head is forthcoming, probably within 2 months, as it is still being refined. And there will be more versions, such as an alligator head.
If anyone has specific questions feel free to email me at:
Machine Design Specialists, Inc.
Dayton, OH (Home of the worlds first successful homebuilt aircraft)
[email protected]
[email protected]
