HXr and HX Combo Help
Bayou Bert
I now have all the sensors working and reading right on the
main, HXr, screen. I have the 8"HX for the second screen.
Have the Ethernet cable hooked between them and on boot up
tells me communication between them is OK.
I went into the primary and set the engine oil temp limits.
That shows up on the second screen. But the MAP on the second
screen is not reading the same as the MAP on the primary screen.
The second screen sees the GPS etc.
My plan was to use the second screen with the engine page up
during flight, so I need to the two to agree.
What am I missing on setup, like they don't have enough options.
Sure like the way they look and glad I bought the 10" primary.
Suggestions appreciated.
setting match?
Bert
Did you configure the aux input on both screens the same? If you did not tell the second screen that the aux that is connected to the MAP is what it is then it will read wrong. All the settings on the engine limits and Most on the Graphical engine setup pages should be the same. The aux functions definitions is the important part for your issue.
