cardinalflier
Yesterday, in the run up area, I noticed a 4-5 amp negative discharge showing on my Dynon Skyview that I installed 3.5 years ago in my RV6. Back at my hangar, I started checking simple connections, starting at the alternator. The only thing I found was a snug, not tight, but not very loose positive battery cableconnection at the battery ( an Odysse 680). I tightened the connection, fired up, and everything read normal. Today, I got a negative 55 amp reading, with the engine running or not running, but with the master turned on. No smoke, no fire, no hot wires, no popped circuit breakers, no obvious clues. Any thoughts as to where to start trouble shooting. Battery is 3 years old and the Plane Power alternator is about 3.5 years old. Do the Dynon shunts go bad? Thanks in advance for any and all suggestions.
Bruce Estes
Bruce Estes
