Hub Caps
Miata76
I'm New Here
Has anyone opted for hub caps in lieu of wheel pants on their RV-12?
  • Drill hole to access valve stem?
  • Plug hole?
I was looking initially at using an electrical conduit plug to fill the potential hole in the hub cap; however, those plugs appear to be far too tenacious. I destroyed three vetting the process on scrap metal.
Any insight would be greatly appreciated!!
Kevin.
Yep-- use the Matco caps!
I've seen drag data indicating the covers like this will give you 30%-40% of the drag reduction od pants. Now if you go the full route with gear fairings and intersection fairings at both ends, that's another story, but that package is a LOT more expensive than these caps.
Wayne 120241/ 143WM
