JeremyL
So after assembling/dissembling (x10) the HS00005 rib to the aft side of the front spar. I riveted them into place. I thought I had fixed the issue of HS 00005 rib rubbing on the shop head of the extremely close adjacent rivets(outboard) but alas 2 are ever so slightly rubbing the 00005 rib. So my question is, what should I do to rectify this rub, surely I can’t just leave it and call it good? Is a dab of rtv an acceptable fix? Is drilling out and flipping the heads of the 470 rivet a fix? If I wasn’t at work, I would go snap and include a picture, sorry. Hopefully my explanation and question make sense? Thanks guys!
