ERushing
Has this happened to anyone? After laying up the 2 interior layers of FG on the HS Tips and cleco'ing them to the HS, the layup bowed out so much that the elevator couldn't pass without rubbing. I had to push it in (toward the front of the HS) to let the elevator pass and ended up with this when the layup dried.
Any idea why this happened? I haven't seen this on any builder sites.
My plan to fix it is to lay up small pieces of cloth until the layup is ~1/8" from level with the edges and then shape the remainder with micro and sand smooth.
Any suggestions?
Thank you!
![0c543bfb-040b-4ccf-8db4-d7bea6d3f850_zpsr3fbob9x.jpg](/proxy.php?image=http%3A%2F%2Fi1373.photobucket.com%2Falbums%2Fag387%2Ferushing1%2F0c543bfb-040b-4ccf-8db4-d7bea6d3f850_zpsr3fbob9x.jpg&hash=2bd704879bdaa22e15ba78010b973aac)
Any suggestions?
Thank you!
