NorthernRV4
I'm pleased to report I'm making progress again, albeit sloooow. After much playing around trying to position the elevator centre hinge brackets so they were perfectly inline and wouldn't move when I clamped them down I finally drilled the first hole. Wouldn't you know that the clamp let the assembly slip about 1/16 to the left but only after the drill bit started to cut. So now I have a thru hole and a problem. That wasn't a good morning but I'm sure I can save it. This hole gets drilled out to accept a 3/16" bolt so if I'm REALLY careful I should be able to drill away all my worries. Just wondering if there is a drill bit I'm not aware of that would be less likely to follow the pilot hole. I think if I split the difference and feed extremely slowly with 135deg split point bit it should be ok. I've considered making a drill jig block that clamps in place to keep the bit from "wandering" but I'd love some suggestions. I plan on clamping the whole assembly in my drill press to keep things from moving.
![](/proxy.php?image=http%3A%2F%2Ffarm8.staticflickr.com%2F7382%2F10401618063_8c546a85df_z.jpg&hash=47cb3a47b89f87daf18063c94e5a2bd5)
More HS spar by jim_soutar, on Flickr
[/url]
Untitled by jim_soutar, on Flickr
![](/proxy.php?image=http%3A%2F%2Ffarm8.staticflickr.com%2F7369%2F10412217444_b4a9625063_z.jpg&hash=b2b137c5088504866afd815f1593cb96)
![10412222255_3ef037226b_z.jpg](/proxy.php?image=http%3A%2F%2Ffarm4.staticflickr.com%2F3698%2F10412222255_3ef037226b_z.jpg&hash=67d149253666f810d4850d3514bd8d28)
