I see that you have no response from RV 8 builders on your question. I have an RV9a and I did adjust the angle of incidence on the HS. Actually, my plans explain how to do this if necessary--if I remember correctly it is in the flight testing section of my manual.
After the aircraft was rigged properly, I set it up in my typical cross country configuration. This included my wife and I along with 60 lbs in the baggage compartment (she really has to work to stay within her baggage wt limit but I digress), mid fuel levels, 65% power, and a cruise altitude of around 10k density. I then checked where the elevator counter wts were relative to the HS "caps". Mine were up (elevator trailing edge down) by around 3/8 to 1/2 of an inch. This indicates that there was too much "down force" built into the HS given my eng/prop/cg and therefore the elevator has to be down (counter wt up) to balance this condition. I discussed this with Ken K. at Vans and we estimated the thickness of an additional shim for the front attach of the HS to correct this condition -- BTW, Ken also did this to his RV6. I am sorry but I don't remember the exact dimension needed to correct but we hit it the first time. The elevator is now in trail in my typical cruise condition.
If you decide to do this be careful and follow the instructions in the manual---all aircraft need some HS downforce to provide stability. If you change the downforce too much you could negatively affect the stability of your aircraft!!! Some of our aero engineers can explain the implications of this far better than I .
BTW, I was expecting a speed increase as a result of this. I thought that the elimnation of drag created by the elevator being down in cruise would result in increased cruise speed--if it did it was a very small amount.
Hope this helps!
db
