HS CradleTemplate
R Eleew
Member
Is the Template for the HS Cradle supposed to be somewhere in the Emp. Kit? I see the VS template/cradle but no HS template or cradle.....
Thanks....
Thanks! Got it... I see now it can be utilized for the VS and HS.....
Wow... these holes sure line up nice!
fuel tanks
Later on you can make a fuel tank fixture from the same boards. Trace a tank rib and recut.
Steve
You may find that you have some difficulty getting the nose ribs all the way into the skin leading edge while in the template - there is not much wiggle room. I laid my HS flat on the work bench for that part, and just used the templates as a holding fixture for the rest of the work, like a cradle.
