I just started building my new RV-4 and first issue arose.
I drilled one side of each HS bracket to the spar.
Now, manual says to mate the other half of the bracket installing the bearing with nut and bolt and a thin washer (AN96010L). In this way the proper distance between the two halves is achieved and the second half of the bracket may be drilled on the spar, too.
Problem is that the edge-to-edge distance of the bearing itself is 16/32'' (not including the washer thickness) but drawing number 3 and 5 call for 7/16 gap. Also the bearing table at the beginning of the manual says a 7/16 thickness for MD3614M bearing. I measured those bearings and their "body" is in fact 7/16, but the edge-to-edge is 8/16''.
Now, if the distance between brackets is set to 7/16'', provided that the bearing overall thickness is bigger, torquing the nut will produce an angle in the bracket side, since at the top of the bracket, where the bolt is located, distance is bigger than that at the bottom of the bracket, where bracket is riveted to the spar. I guess this is not good.
So, I am almost convinced to distance them of 8/16''.
Will this be OK?
Thanks.
Camillo
Will this be OK?
Thanks.
Camillo
![2nv3tb9.jpg](/proxy.php?image=http%3A%2F%2Fi47.tinypic.com%2F2nv3tb9.jpg&hash=37be29397793921110545445c3394c44)
![xddptw.jpg](/proxy.php?image=http%3A%2F%2Fi46.tinypic.com%2Fxddptw.jpg&hash=a562301d40e2de0ee2533e30b690ce65)
![33u52xg.jpg](/proxy.php?image=http%3A%2F%2Fi49.tinypic.com%2F33u52xg.jpg&hash=1b16ac73f142021ab1924ac2641a3748)
