AJ85WA
Hi Guys
Im starting to fit my HS to the aft deck.
I have got the two spacers under the front spar and fuselage has been leveled.
The instructions say to put a 3/16 spacer under the rear spar to get it level.
I have got two #30 drill bits through the tooling holes and a level over the drill bits. When the level reads 0 I can not fit the 3/16 drill under the rear spar(only just)
But my question is the bottom skins of the HS is touching the aft deck when everyting is correctly leveled. Is this ok?
