Aileron1999
Member
Question for the brain trust. On page 10-04 step 1, It has you fabricate the HS Attach bar from a piece of aluminum angle. The measurements are quite precise, however when I try to use my band saw with a metal cutting blade I can not get anywhere near as accurate as the instructions indicate. The saw blade bends quite a bit and it seems impossible to get a clean straight cut. I am wondering what tool others have used to cut this piece.
Eric
Eric
