Hi,
I came to my 1st major head scratching.. the instructions ask to cleco hs702 hs603 hs 706 hs707 and hs708
I found that I need 5/32" clecos which I didn't have then so I placed an order at Cleaveland.
While waiting for the clecos I thought of using the skin to align all the parts together for the drilling. This method seems to workout ok despite the fact that I have to struggle with the leading edges of the ribs. They scratched the skin bad. What bugged me and I am seeking your input here is why the forward tip flange don't lay flat with
One more confusing point is, I enlarged the 8th hole in the aft spar HS603 to #21 as per the instruction (where I needed the black cleco) the problem is the holes attach to HS707 flange where the holes are undersized #30 The black cleco won't go through and the copper one will be lose.
The plans state clearly to enlarge them later, but I am thinking of enlarging them BEFORE attaching the rib. What do you think?
Mohammed
![l.hs.assembly.1.jpg](/proxy.php?image=http%3A%2F%2Fsaudirv.com%2Fimages%2Fl.hs.assembly.1.jpg&hash=6d604d19dd3dc9c96a9d34575584bf80)
![l_hs707_and_skin.jpg](/proxy.php?image=http%3A%2F%2Fsaudirv.com%2Fimages%2Fl_hs707_and_skin.jpg&hash=ac69619e69887b9e18ca506ebe5de4cb)
![hs708_hs603_holes.jpg](/proxy.php?image=http%3A%2F%2Fsaudirv.com%2Fimages%2Fhs708_hs603_holes.jpg&hash=b17dd84251710f70954fdc54f8f6a93b)
Mohammed
