llavalle
Hi,
Long story short, I must redo one of the 2 ?L? brackets of the empennage of my -9(one of the angle rotated during drilling of the 2nd hole). Since the empennage kit does not come with enough material to make another one, I called my brother who works for a machine shop. He asked me for the material. So, here?s the first question:
1-What is the material? I assumed it was 6061-T6, and it was extruded (Part number AA6XXXX)... Contacted vans and they told me to order a replacement "AA6-187X2X2 1/2X5" and re-do it... AA6 angles are listed as "6061-T6 angles" on the webstore
He used a CNC to make the new angles. For some reasons, he used 7075 aluminum. Right now, it?s not heat treated, it?s a 7075-T0. He checked and he told me that bare 7075 has a tensile strength that is inferior to 6061-T6. He suggested we heat treat the 7075 to a T6... a 7075-T6 has more than 2x the tensile strength of 6061-T6 So, the other questions are:
2-Is 7075 BARE (T0) OK for this application? After all, 6061-T6 might have been chosen because it?s a lot cheaper compared to 7075.
If it?s not OK,
3-Is 7075-T6 ok for this application? I?ve read somewhere that 7075 is more brittle, but that was not a good source and it might not be accurate.
I?ve got 4 choices
1-Keep the 7075-T0
2-Heat treat the angle to a 7075-T6
3-Re-fabricate the angle with 6061-T6 no cost, the cnc program is made, put metal in CNC, hit the Start Button.
4-Re-order AA6-187x2x2 1/2X5 and re-fabricate... the part is only $5.96 but shipping, exchange rate + brokerage to canada will end up $20+ and waiting a couple of days.
What should I do? Asked Vans about it and they told me "We will not speculate on the 7075." What do you think?
If it?s not OK,
I?ve got 4 choices
1-Keep the 7075-T0
