llavalle
Alright, me again...
I'm having trouble with some fitting between the HS-902 Spar and the HS-904 ribs. The 3 holes that are side-by-side through the spar are fine. Its the top and button holes that don't fit at all.
To make sure I was not missing something I took couple of measures. Note that none of the measured holes were enlarged.
Measured the spacing on the HS-901 skin, it was 0.814"
Measured the spacing on the HS-904 rib, it was 0.812"
Measured the spacing when both(HS902 and HS904) were attached together, it was 0.861... it's almost 0.050 too wide.
As you can see on the last picture, the rib is firmly touching the spar... the fit is good for those 3 holes (filled with clecos)
Do I need to bend something to make it fit?? Or maybe the the HS-902 Spars are mis-punched? I checked both of them and they have the same problem. Unless I'm seriouly missing something
What do you think?
What do you think?
