Quick question.
I?ve tapered HS-710 per the drawing, and it says to taper HS-714 similar. Does that mean to maintain the R1/4 and taper back 2.5 inches from the end, which will be at a greater taper angle since HS-714 is 1 inch wide and HS-710 is only .75 inches wide, or does it mean to maintain the same taper angle as HS-710 and extend the taper back further on HS-714? That would extend the taper back about 4.75 inches from the end of HS-714?
