When bending the HS-714 forward HS spar angle, despite carefully bending in a vice with a mallet, I over bent the angle to 7 degrees. I then tapped it back, but it went to 5 degrees and then back to the required 6 degrees. Is this part still serviceable or are there issues with work hardening or fatigue?
