Just have a question regarding the HS-710 and HS-714.
On the plans DWG 3, looking at the view A-A. There are 4 holes where it says "enlarge/drill 3/16 dia. in assembly with fuselage, 4 places".
Is that something that will be done later on, or should it be drilled through with the HS-702 ? I already drilled a couple of them, is this a big deal ?
Thanks.
Thanks.
