Simon Hitchen
Im having a problem fitting HS 707 (leading edge midspan rib) into the 601PP (pre punched skin) when attached to the skeleton. The fit is so tight that I really have to pull the trailing edge of the skin back to fit the TE spar. Is this normal. Ive checked the plans, everything is in place and measures up.
