pilotian
I have come to a point where I am sorta confused how I will be doing the next step today.
As per the directions I did the left horizontal Stab and it turned out just dandy and better than I anticipated. So coming of a "win" I have continued to plug away at the reast of the HS! So..... I of course went per directions and attached the rear spar channel to the rear spars and riveted all that up for assembly at the end of the process.
My real problem is I just am having a hard time visualizing the thought of attaching the HS-707*(*could be HS-708, I dont have the plans infront of me right now, at school!) front nose rib in the middle of the right HS. Since the directions say to repeat the process for the right, i continued to attach the right front flange to the center HS-810 and such and now it is permenant to the right.
I am confused how I am going to reat the HS-707* now when it is time? Will I just reach through the front part where the HS-405 would be and not put the HS-405 nose rib in until after. Or is there another way that I am not thinking of.....
Obviously going from the back isnt an option do to the permenance of the flange. Are the directions wrong or so they just like close calls!?
(we wont get into the whole 405 2 hole problem I have... thats another topic haha)
