mototopo
I'm ready to match drill the holes on HS-405 and HS-404 rib's on my empennage but I stopped because I noticed that, when clamped to the skin, the HS-405 rib push the HS-702 spar a little forward. I was concerned about the edge distance of the holes on HS-702 flange so I marked the hole position and measured. On the inboard hole (the one closest to HS-405 rib) I have just 0.196" that is the minimum edge distance allowed for a 3/32" rivet, but a little less of the edge distance of the prepunched holes already present on the HS-702 flange (the edge distance become greater going outboard).
Am I ok or should I make any correction? I'm unable to push HS-702 backward because it's already in contact with HS-405's flange (that is clecoed to the rear spar) so I don't have space to move it.
Thanks!
Thanks!
