VAF,
While slowly cruising along on the horizontal stabilizer spar preparation, I believe I'm about to run into an issue. I previously cleco'd together the HS-702 spars, HS-00003 spar doublers, and the HS-810/814 angles and drilled all holes inboard of the 6 degree bend line. The HS-00003 was already pre-drilled so it took all the guess work out of hole placement (or so I thought). My next step is to make the relief notches in the HS-702 spars. However, once I make the 1/4 inch holes, the edge distance minimums will be broke. I will only have between .174 to .230 inches on the closest 4 rivet holes if I proceed. Has anyone seen this before and have any advice? Thanks in advance!
Dustin
(3rd time poster but 1st time picture attempt. Fingers crossed it works)
Dustin
