I just bent the tabs on the HS-702 forward spar to 6 degrees using wood blocks. Both are at 6 degrees but the bend line on one seems less crisp and bigger radius. I think the block may have shifted inboard when bending. Can I use this as is? My thought is that this is all going to be smooshed together between the HS 710 and 714 reinforcement angles and HS-00001 doublers anyways.
Thoughts?
Here are some photos. The bottom spar is the one in question.
https://photos.app.goo.gl/oUJwjLLVSPP6y8NFA
Thoughts?
