rv8_builder
Active Member
I am new to airplane building and started the horizontal stabilizer with great enthusiasm this weekend.
That is until I made the first mistake on HS 404 ? I overlooked the part in the manual that states ?make a left hand and right hand? when cutting out the nose ribs!
I drilled holes in the corner of each cutout to make a radius in that area. Only after drilling the holes I realized that I had made two left hand ribs. Fortunately I could partially correct my mistake by drilling two new holes offset the other way, before cutting out the corners.
I now have an additional hole in the right hand rib.
Can I use this rib or do I need to replace it
![hs404.jpg](/proxy.php?image=http%3A%2F%2Fi46.photobucket.com%2Falbums%2Ff123%2Fburgera%2Fhs404.jpg&hash=bfb8514cdd8d1e2807d59a89e5b497f3)
