Adam Oke
Well, I figured it would come sooner than later. Sure enough it occurred at the particular spot that I thought it would.
Working on the left horizontal stabilizer.
I used a right angle drill attachment. The reinforcement angles edge distance is ok. But I blew it on the HS-404 flange.
The holes are both approximately 0.184 and 0.173 from edge to hole centre. What do you think?
*fingers crossed* Someone please say build on.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Be sure that the front flange of HS-405, HS-702, HS-801-1, HS-814-1 and the aft flange of HS-404 are pulled up tight. Re-clamp the upper and lower flanges of HS-404 to HS-801PP. Drill the HS-405 to HS-702 to HS-810-1 or HS-814-1 to HS-404 inboard rib attach holes. Use the holes previously pilot drilled to #40 in the forward flange of HS-405 as a drill guide (See SEC D-D). It is best to use an angle drill for this step, but a long drill bit will work.
![DSCF0134.jpg](/proxy.php?image=http%3A%2F%2Fi64.photobucket.com%2Falbums%2Fh169%2FAdamOke%2FDSCF0134.jpg&hash=7d7838ae06297dffaca704c40e2369eb)
