Hello,
I am at section 8-7 step 2 in the RV-10 build. This is the beginning of establishing the HS skeleton. The front and rear spars are already built and primed. Step 2 has me bending the HS-1004 INSPAR using some "exacting science".
"This bend can be accomplished by holding the forward portion of the rib against a solid surface and pressing down along the bend line with your fingers. The part will bend along the bend line between the two notches as shown"
I am worried that my bend is at the edge of the notch, closer to the trim cable hole and possibly causing a stress crack to eventually occur. I will call VAN's and ask for their advice but I also value the collective wisdom of this forum. One option may be to enlarge the notch to relieve the potential stress point.
![2ngbd54.jpg](/proxy.php?image=http%3A%2F%2Fwww.vansairforce.com%2Fcommunity%2FIMG%5Dhttp%3A%2F%2Fi57.tinypic.com%2F2ngbd54.jpg&hash=49ceb4c1f3b112ec6b430b3ea2ac4700)
![Section%208-9%20of%20RV-10%20build.jpg](/proxy.php?image=http%3A%2F%2Felstien.us%2FRV-10%2520Build%2520Log%2520and%2520Information%2FPicture%2520Albums%2Finspar%2520ribs%2520of%2520VS%2520bent%2520per%2520instructions%2FSection%25208-9%2520of%2520RV-10%2520build.jpg&hash=2d6aeced0c417375aedcab5cd40b47ba)
