IowaRV9Dreamer
My tribulations with the slider canopy frame continue. As of now:
The problem is that the canopy frame has a twist to it - when mounted on the plane the aft side of the right square tube is about 1/4" lower than the front side - in other words it is not parallel to the longeron. The left side square tube is parallel to the longeron.
The resultant twist is making it so the rear round tubes cannot both be in the correct place relative to the aft fuselage. If I temporarily take out the twist on the plane with clamps - the canopy frame is PERFECT!
So what I need to do is take some twist out of the canopy frame. So far I've been clamping it to my work bench and using a piece of conduit as a lever to twist it.... with no result other than a bent conduit.
I think my next attempt will be an 8' 2x4 and two people to generate the twist.
I don't want to bend the rear bows - since they seem to be the right shape now.
Has anyone else had to untwist their canopy frame? If so, how did you accomplish it? Never has 1/4" seemed so far![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- The shape of the square tubes matches the shape of the fuselage side.
- The square tubes are 1/16" inset from the outer edge of the fuselage side per plans.
- The shape of the front round tube matches the shape of the roll bar.
- The height of the front round tube is 3/8" above the rollbar per plans.
- The shape of the rear round tubes matches the shape of the aft fuselage.
