How to remove switches
BH1166
I need to remove switches for panel upgrade. I can’t determine the manufacturer, in turn can’t determine how these detach. They are individually installed, not a bracket of sorts with all attached. Thanks
They look like Honeywell AML switches.
https://sps.honeywell.com/us/en/pro...es/rocker-switches/aml-series-rocker-switches
Try pushing from the rear and wiggling them around. Spring clips hold them in place with a wedging action.
Thanks Mike/Larry/John/Keith…. Dim sumsabitches did NOT want to release. Precision hole for the 7 left little to no “wiggle room”. Made a couple tools to shove between, ( I named it :) ) removed and wiggled best I could and got one to finally pop loose. Found out no service length, so to get it out, not only did I have to get EIGHT wedge clips to let go, but the connections had to come off too. Thanks as always for the crazy good support you get from other RV’rs.
