It can be tough. I was able to do it with my fingernail. I avoided using a metal blade for fear I would mess up the flange. Maybe a thin plastic pry bar.Is there a trick to getting the nozzle out of the fuel injector body?
I have found sticky duct tape to work well, a small piece of tape pressed on the flange and the restricter comes right out with no damage.Is there a trick to getting the nozzle out of the fuel injector body?
The whole assembly got 30 mins in hot hoppes in the ultrasonic cleaner last night, still can't get them out. I don't have a spray pattern, just a narrow stream. Perfectly matched on all cylinders though. The restrictor piece won't budge with a razor or fingernail.
Could having cranked down the fuel line fitting too tight cause it to be stuck?
Indeed -- a picture would be useful...Please be sure your not using the old style nozzles . They do not come apart.!
Ah yes, that could be a problem - especially if I managed to get them apart!Please be sure your not using the old style nozzles . They do not come apart.!
Don't think that one comes apart. Just looking at some of my old nozzles. Appears to be the same. Can you show me a picture of the bottom?
