I’m trying to remove the impulse magneto spacer. I’ve got the left mag off, wrapped my fingers around the spacer, pull enough to slightly move the plane but the spacer won’t budge.
Is there a trick? I don’t know what tools are OK to use. I will be removing the studs, so maybe studs before spacer? I have a stud remover on order from Amazon - the one recommended in kitplanes.
I’m installing electronic ignition, and need to use the spacer in the right side to give the ignition pack mounting plate clearance from the motor mount. Maybe there’s another alternative? Someone has a spacer and studs they don’t need?
