lndwarrior
I have three original instruments in my panel that have the 2-1/8" hole. I am considering replacing two of these with instruments that are only available in 2-1/4" hole.
So how do I cut the extra 1/8" out of the existing installed panel?
I'm guessing there is a simple answer to this but I can't figure it out. Obviously the cuts have to be precise.
I'm not crazy about trying to grind it out but maybe that's the only answer?Tape around the hole, draw the enlarged circle and go to town with a grinding stone on the dremel? Also try and cover everything from the flying debris!
Hoping there's a better idea,
TIA
Gary
TIA
Gary
