In the 7 plans they suggested two ways. One was a long full length pin, the other was to remove two lugs in the middle of the hinges and use two, half length pins. This is what I did as well. Bent the ends 90 degrees to make a handle and I put a nut plate under the handle and I secure it with a little tab of aluminum held against the handle with a screw through it into the nut plate. My pictures are a mess (next big project is to organize them!) or I would include a picture.
