Doug Rohrer
I had to replace a leaking pushrod tube seal on my O-320. No problem getting everything off. However, the tappets seem to be holding the pushrods out enough to prevent sliding the rocker shaft back in through the bushings in the cylinder and the rocker arms. What is the trick to depress the pushrods and rocker arm enough to slide in the shaft? I am standing by at the hangar. Thanks.
