Have we all been driving EFI cars long enough to forget what it was like to start a flooded mechanically injected or carb'ed car?
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It was (or is, if you have one) SOP to mash the pedal to correct a flooded condition.
SNIP
Yes, it was SOP to go full throttle on those old cars to clear a flooded condition. However, it was to force the choke open (they had a linkage such that full throttle opened the choke, at least part way). If the MAP is ambient when cranking at partial throttle, you can't get more air in by going full throttle, as others have already said.
No one has yet mentioned using the purge valve. Is anyone spun up on its use? I believe it is mechanically opened to allowed the boost pump to pump fresh cool fuel into the injection lines. I guess that's all well and good so long as the plenum has no fuel in it. In other words it seems the sniffle valve would be a cousin to the purge valve in operation.
I have a purge valve, but I believe its main benefit is not in circulating cool fuel through the system pre-hot start. It is in preventing fuel from puking into the engine after shutdown. Only a tiny amount can still go in the engine, specifically that which is downstream of the purge valve, which is attached to the flow divider.
A few weeks ago I got to the hangar and noted some blue staining on the floor under the engine. Uh-oh, that never happened before. I got a flashlight and looked up inside, and could see fuel had dripped from the small hole in the FAB which is inside the filter (yes, I have another hole outside the filter). Hmmm. I then noticed that the purge valve had been pushed in. I remembered doing this to help a passenger egress on the previous flight. Most px's get out ok without it, but this time for whatever reason I needed to push it in. So, fuel barfed into the engine after shutdown, and some made it to the ground. Does it really matter? Don't know.
I do use the purge valve pre hot starts for maybe 10 seconds, to ensure fumes are out and relatively cool fuel is in. Then, 1/4 throttle, mixture ICO, then slowly in it catches. Seems to consistently take about 8 blades to fire, but quite reliably so. I've been too chicken to experiment with alternate hot start methods!
