After the princely total of 25 engine hours since new, it appears that one of the solid state ignition modules of the Rotax has died. Symptoms include an instant complete shutdown when turning off the B ignition switch (ie., A circuit is dead), and swapping the ignition harness connections between the A module and the B module transfers the exactly the same problem to the B circuit.
Since these ignition modules cost over $1K each, seems like the next step is to go for replacement under warranty. Does anybody know how to initiate a warranty claim to get replacement Rotax parts in the US?
Thanks in advance,
-Dan Masys
RV-12 N122LD now AOG![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
RV-10 N104LD flying quite nicely ;-)
Thanks in advance,
-Dan Masys
